Old 05-01-2014, 10:18 PM
Nice job, Sam!
Old 05-01-2014, 10:42 PM
IH Cub Cadet IH Cub Cadet is offline
My pads were almost down to the steel, new pads are 3/16" thick
Sam,
Thanks for the info!
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 05-02-2014, 12:47 AM
Glad you got the Scrapper out of the shop
149 is coming right along. Don't know (remember) if you mentioned how the trunnion is. Most likely something else you need to add to the list.
Old 05-02-2014, 06:48 AM
Brakes turned out good Sam!
Old 05-03-2014, 05:09 PM
Got the trany lever fixed today. See post # 7 http://www.onlycubcadets.net/forum/s...ad.php?t=31729
Pulled the rear cover off all good inside, I'm a happy camper. New axle seals on order. Best part was that the new wiring harness from Mike Lamar showed up today. Hope to have the old girl running next week.
Old 05-03-2014, 07:55 PM
That 149 is going to be sweet when you are done with it Sam!
Old 05-03-2014, 09:20 PM
Great news, Sam!
Old 05-04-2014, 12:01 AM
Doesn't look too bad in there. You pullin the tubes and drilling the case like usual? Or not going to the trouble?
Old 05-04-2014, 05:41 AM
Jon
I'm not pulling the tubes and drilling the case on this one. I'll use my suction gun to get the water out of it. I can do that through the ends of the axle tubes. I figure it's lived for 32 years the way it is.
Old 05-04-2014, 05:41 PM
Cleaned out the rear, drilled and tapped the broken mount bolt, looks like the PO had a 7/16" bolt in it so I just drilled and tapped it for 3/8" like it should be anyway, came out nice. Took the new wiring harness out so you guys can se what Mlamar makes, nice and everything is tagged so you know what goes where. Axle seals should be here next week so hope to get the old girl running soon.
