#121
Nice job, Sam!
#122
Sam,
Thanks for the info! Bill
IH Cub Cadet 109 IH Cub Cadet 126 (2) IH Cub Cadet 149 IH Cub Cadet 1650 MTD Cub Cadet LTX1042 |
#123
Glad you got the Scrapper out of the shop
![]() 149 is coming right along. Don't know (remember) if you mentioned how the trunnion is. Most likely something else you need to add to the list.
#124
Brakes turned out good Sam!
#125
Got the trany lever fixed today. See post # 7 http://www.onlycubcadets.net/forum/s...ad.php?t=31729
Pulled the rear cover off all good inside, I'm a happy camper. New axle seals on order. Best part was that the new wiring harness from Mike Lamar showed up today. Hope to have the old girl running next week.
#126
That 149 is going to be sweet when you are done with it Sam!
#127
Great news, Sam!
#128
Doesn't look too bad in there. You pullin the tubes and drilling the case like usual? Or not going to the trouble?
#129
I'm not pulling the tubes and drilling the case on this one. I'll use my suction gun to get the water out of it. I can do that through the ends of the axle tubes. I figure it's lived for 32 years the way it is.
#130
Cleaned out the rear, drilled and tapped the broken mount bolt, looks like the PO had a 7/16" bolt in it so I just drilled and tapped it for 3/8" like it should be anyway, came out nice. Took the new wiring harness out so you guys can se what Mlamar makes, nice and everything is tagged so you know what goes where. Axle seals should be here next week so hope to get the old girl running soon.
