Old 10-14-2012, 08:53 AM
cadzag72 cadzag72 is offline
nice haul! my 125 has the same brake/shift lever issue. I know how to fix it, just haven't had the chance yet. if you take the battery out and follow the rod the shift lever is attached to, you'll find a wedge-shaped piece and pin sticking through the shaft. this just needs some lubrication. it's designed to cancel the shifter back to Neutral when you step on the brake, but if there's no lube, it'll bind. It's easiest to find if you move the brake pedal around while you're looking. some wd-40 will do the job, I'm going to hit it with that and maybe some white grease too. Hope this helps, and hope you have a blast with it!
Ian
Old 10-14-2012, 05:12 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Thanks, It is a fun little tractor... I havent got a chance to do much with it yet. How are the hydros with plowing snow? Better than a gear shift?
- Cory Sanderson
Old 10-14-2012, 07:52 PM
I'll be finding that out myself soon.
Old 10-14-2012, 08:42 PM
ihcc104's Avatar
I cant wait for the snow to start flying so I can go out and play and push it around. I also cant wait to try out my CQ-36 snow thrower for the first time!
- Cory Sanderson
Old 10-14-2012, 11:10 PM
When your plowing at a plow day a hydro is nice when your stuck behind a off topic tractor. Cub123 has done a many furrows with his 123.
What are you up to now?
Old 10-14-2012, 11:58 PM
red56turbo's Avatar
Congrats on the 123 score! I used to have one and kinda regret getting rid of it. Looks like you got tons of parts as well.
Josh
Diesel Cub Cadets...........
Old 10-15-2012, 12:14 AM
ihcc104's Avatar
Thanks, Yes... I think I will have this one for a while... I gotta figure out why she is smoking... It only smokes out of the muffler when it increase throttle and a little bit of smoke seems to come out of the oil breather... No clue. I haven't opened up a Kohler before and am worried about getting in too deep...
- Cory Sanderson
Old 10-15-2012, 12:17 AM
I'm adding another hydro to my collection.
Old 10-15-2012, 07:48 AM
nikster's Avatar
nikster nikster is offline
I love to read about great deals like this! Just seems that some people just plain give up?
Get it outta here! NOW!
Nik,
Old 10-15-2012, 08:58 AM
What you up to Allen?!
