nice haul! my 125 has the same brake/shift lever issue. I know how to fix it, just haven't had the chance yet. if you take the battery out and follow the rod the shift lever is attached to, you'll find a wedge-shaped piece and pin sticking through the shaft. this just needs some lubrication. it's designed to cancel the shifter back to Neutral when you step on the brake, but if there's no lube, it'll bind. It's easiest to find if you move the brake pedal around while you're looking. some wd-40 will do the job, I'm going to hit it with that and maybe some white grease too. Hope this helps, and hope you have a blast with it!
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! ![]() |
Thanks, It is a fun little tractor... I havent got a chance to do much with it yet.
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
![]() Quote:
I cant wait for the snow to start flying so I can go out and play and push it around. I also cant wait to try out my CQ-36 snow thrower for the first time!
![]() Quote:
What are you up to now? ![]() |
Congrats on the 123 score! I used to have one and kinda regret getting rid of it. Looks like you got tons of parts as well.
Josh Diesel Cub Cadets........... |
Thanks, Yes... I think I will have this one for a while... I gotta figure out why she is smoking... It only smokes out of the muffler when it increase throttle and a little bit of smoke seems to come out of the oil breather... No clue. I haven't opened up a Kohler before and am worried about getting in too deep...
![]() Quote:
I love to read about great deals like this! Just seems that some people just plain give up?
Get it outta here! NOW! Nik,
It dont cut grass, but its yellow. |
What you up to Allen?!
