Good luck on the rebuild. If you look in my profile, I did a similar project last year. I don't know how close to Milan Indiana you are, but I might have some of the parts you need for that. Just let me know what you need.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
![]() Quote:
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
It's good to know there's someone close if I might need something,( parts or info.) Shelby Co. is were I call home. Been threw Milan several times on the bike. We really like your Reservation resturant you have down there. Try to time it so we call eat there each time we go threw. The biggest thing I guess I been looking for is an engine. $$$ YIKES This one has a small hole in the right side of the block were the rod broke. Bent crank maybe? The hole is about the size of a dime. Thanks ajgross
Congrats! I'm looking forward to your progress and pics!
PM sent about engines.
AJ
Good luck with the rebuild. To me it is a very self satisfying to rebuild something left for dead. Always a challenge.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Wow,
She did sit outside for awhile. Atleast it doesn't look as bad as that Murray sitting behind it. ![]()
Josh Diesel Cub Cadets........... |
![]() Quote:
the only good thing I see about that picture is "most" of the time you get the tractor cheap
![]() Quote:
Thread Tools | |
Display Modes | |
