I got my 782 home today . It's really rough and needs some TLC. Rod threw the block and been sitting outside for quite awhile. Shifter won't move, hygraulic lever won't move, brake pedal was froze. I sprayed all moving parts with blaster and letting it soak for a few days. If it turns out this thing is worth saving I have a 16HP V-Twin Briggs to drop in. Brucer95 (son) told me some on here have done it. Anyhow I'm going to save her if I can.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
Good luck on your 782! Thanks for the pic.
Congrats on the 782 pickup!
Looks like a long road ahead of you...eventually you will come to the end and realize it is worth saving.New these were like $3000.00
You have a doable project tractor. (reminds me of the 147 that I drug home last summer.) Lots of time and dollars and you can have a great tractor. Will be watching your progress if you decide to get into this one.
Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
I agree! Will throw in
![]() ![]() ![]() Correct me if I am wrong...but there is at least $500.00 worth of parts sitting on the trailer alone ??? Worth saving I'd say!
Mike Ontario, Canada IH built 982, IH built 782, IH built 782 parts tractor, 100 w/fenders & lights, #4 trailer, 42" front blade, IH 2B tiller, 12" Brinly plow, Brinly cultivator, IH push mower, Sims cab, IH snowthrower, 450 blower. ![]() ![]() ![]() ![]() |
Don't give up on trading that Briggs for a Series II Kohler KT 17.
Cub 108 Cub 1650 Cub 1000 Cub 682 Super Cub 2072 |
Great save on the 782. Bring that thing back to life!! Looks like an earlier 782. Has an early grill on it. What's the serial number? Congrats!
Josh Diesel Cub Cadets........... |
red56turbo,The last 6 numbers are679505. The only reason I am considering the Briggs is because I allready have a very low hour 16 V-Twin. But I'm not 100% sure I'll use it. I'll just have to get started on this project and see were it leads.
I'm sure you realize this, but just to make sure...your shifter won't move because your brake pedal is locked in the down position. There is a small lever on the brake pedal with notches on it that should be rotated to release the brake pedal. I can see from the pic that it is in the locked position. Unlock the brake and see if the shifter will move.
Tony Stafford, VA 1650, 682... |
