Old 03-28-2011, 07:32 PM
sfaulkner's Avatar
sfaulkner sfaulkner is offline
Default k161 rebuild
Let me start by saying I have never rebuilt an engine, this is something I would normally pay someone to do. However, I am going to try to rebuild this engine, it is something I always wanted to know how to do. It is a k161 out of the 1966 71 that I am taking down. I have provided a link to some pictures that I took of what came out of the engine. You tell me, is it worth saving? I thought if it is this bad I can’t mess it up. I plan on having it bored, what else would you do if you had it torn down this far. Thanks for any help.
https://picasaweb.google.com/1113792...CKnFl9uYqvObVw
1963 Original
1965 100
1937 F20
It's all designed to blow our minds, but our minds won't really be blown
Old 03-28-2011, 07:39 PM
You should be able to salvage the block. Your machinist will be the final answer on that. He may have to sleeve it. Won't know till he checks it out. The crank is another unknown till it gets miced in multiple places. Again, your machinest can tell you if it can be saved. The cam looks ok from the pics. You should be able to bring this engine back to life. Finish stripping it down and get the major pieces to a machine shop to check the specs and then you will know from there.
Old 03-28-2011, 08:02 PM
By the way, I found this inexpensive GM door spring tool works great for Kohler valve spring removal. Look for it at your local parts house.
Old 03-28-2011, 08:11 PM
sfaulkner's Avatar
Thanks battlewagon for the information. I love the GM door spring tool, I will look for one.
1963 Original
1965 100
1937 F20
