Old 08-31-2026, 02:44 PM
1045orbust 1045orbust is offline
Default Steel Bearings in lieu of plastic bushings
I would like to replace the front wheel plastic bushings on the 2008 LT1045 with steel bearings. Since the plastic bushings come with grease fittings, I would have to drill a hole, tap it for a grease fitting and insert the fitting in the wheel. Has anyone tried that? The plastic bushings wear out too quickly.
Old 08-31-2026, 05:25 PM
Billy-O's Avatar
Billy-O Billy-O is offline
JUst curious..... what STEEL bearings are you getting to replace the plastic bushing?
In my mind, I would consider replacing the plastic bushings with bronze or oilite bushings if it is at all possible. One place to look would be McMaster-Carr.
Plow blade
#2 Cart
QA36 snowthower
Old 09-02-2026, 11:04 PM
Sir, your reply on the oilite bushings will be seriously looked into. The front wheels have an outer and inner plastic bushing and the wheel has a grease zerk. Will the oilite bushings be OK without the zerks?
Old 09-03-2026, 07:58 AM
Probably.....until they wear out!~
Old 09-06-2026, 05:52 PM
PBIjim's Avatar
PBIjim PBIjim is offline
Oilite is an oil impregnated sintered Bronze material. It is designed to be self lubricating for a long time. It doesn't last forever, but it does last pretty darn well. I would expect it to last many years in that application, perhaps even a few decades if you don't drive through absorbent & abrasive environments. Heavy dust contamination can draw the lubricant out of it.
A pair of 100's, both look fairly well stock, one with a creeper, and a snow plow that will never see snow here in south Florida, and now a 122 with a deck
