Old 08-05-2026, 02:16 PM
mkedzierski's Avatar
mkedzierski mkedzierski is offline
Default XT3 Idler Pulley Greasing Tip
Today I noticed the 2 idler pulleys for the mower belt on the front of the tractor seemed dry and almost gritty feeling, not smooth at all. They only have about 25-30 hours of use at most because I don’t mow with this tractor. So I removed them with the idea of popping off the bearing seal snd greasing them. Using a tiny screw driver the seal came off easily without damage and I pumped grease into the bearings that were both starved for grease. See pictures attached. I presume other idler pulleys on the mower deck can be greased the same way. One pictures shows the replacement pulley from Cub Cadet is $60.99 ea… Ouch, not cheap to replace. Hope it works and it saves someone on this forum a bit of cash. May Jesus bless you all.
Old 08-05-2026, 07:09 PM
mrfred54 mrfred54 is offline
Good idea to grease sealed bearings. I have a needle zerk so I don’t have to remove the seal to lube sealed bearings
Old 08-05-2026, 09:16 PM
I use diabetic syringes, been injecting grease in sealed bearings for over 65 years.
It is very rare that I have to replace a bearing.
Old 08-06-2026, 10:03 AM
ironman's Avatar
ironman ironman is offline
Hah! So I tried to buy some syringes to grease my bearings.
Da man come and took me away.
I toll da judge, "Man, all I wanna do is grease my bearings" .
Dat judge slam dat damn hammer and sez "90 days".
Old 08-06-2026, 02:29 PM
I've been using one like this for years on sealed bearings
File Type: jpg lumax-grease-gun-accessories-lx-1416-64_600.jpg (12.1 KB, 52 views)
Old 08-06-2026, 03:38 PM
I want to get one of those. It looks useful for this type of job. Thanks for sharing.
Old 08-09-2026, 08:28 AM
garydee's Avatar
garydee garydee is offline
Default Grease needle
Got one at Tractor Supply not too long ago...
