Old 05-27-2025, 09:35 PM
Jamieoz1 Jamieoz1 is offline
Default Hds 2155 sputter and stall
Hello. I have a hds 2155 what was sputtering when pot was engage. Then it continued after pto disengaged. I empty all thr gas and put new gas in. Same issue. Change fuel filter. Same issue. So then I took the carb off and cleaned it, which does require un hooking the choke wire. Put it back together and when choke is engaged about half way engine runs great. Close choke it starts to shut off. Any help or ideas would be much appreciated.
Thank you
Old 05-28-2025, 07:16 AM
If you have to close the choke partially to make the engine run "properly"
you have a lean condition, in other words you are not getting enough fuel to the engine.
That is usually plugged passages in the carb/main jet.
That said:
What is engaging a "pot"? do you mean a PTO?
Closing the choke means just that, the butterfly shuts off the flow of air causing more fuel to be pulled from the carb bowl enriching the mixture.
It is normal for an engine to sputter, blow black smoke and run bad when the choke is fully "closed" and some will stop ruining completely.
In order for us to help you, we need proper terms so we are all on the same
page so to speak.
Old 05-28-2025, 07:22 AM
ironman's Avatar
ironman ironman is offline
I start to sputter too when I engage my pot.
Old 05-28-2025, 07:42 AM
We think alike ol'Friend
Old 05-28-2025, 04:31 PM
green407's Avatar
green407 green407 is offline
Originally Posted by Jamieoz1 View Post
Hello. I have a hds 2155 what was sputtering when pot was engage. Then it continued after pot disengaged. I empty all thr gas and put new gas in. Same issue. Change fuel filter. Same issue. So then I took the carb off and cleaned it, which does require un hooking the choke wire. Put it back together and when choke is engaged about half way engine runs great. Close choke it starts to shut off. Any help or ideas would be much appreciated.
Thank you
Most likely you need to re-clean the carburetor, somewhere in one of the many tinny-weeny passages is some dirt or corrosion blocking the way.
You're likely getting enough fuel through to run the unit but as soon as you put a load on it fuel delivery can't keep up.
128 X 2, 129, 149, 1250, 1450 x 2
Old 05-28-2025, 07:43 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Is that the one under your bed or in your pipe ?
Oz
Old 05-29-2025, 07:12 AM
ironman's Avatar
Oz
Ha-Ha, I'm fortunate enough to have both.
Old 05-31-2025, 01:49 AM
Ozcub's Avatar
Fiddler on the Roof "If I were a rich man"
Oz
