Old 01-07-2019, 02:00 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Default Head bolts
What head bolts should I use on the 1250? The old head bolts are warped and I really don't want to reuse them. Also, it lists two different bolt lengths, 1 1/2, and 1 3/4 in, which one is right? What grade should I use?
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 01-07-2019, 05:42 PM
twoton twoton is offline
7 @ 1.5"
1 @1.75"
1, 3.5" stud
1 spacer
2 nuts
11 heavy duty washers
All grade 8
Old 01-08-2019, 08:49 AM
Mudrig150's Avatar
Originally Posted by twoton View Post
Attachment 97786
7 @ 1.5"
1 @1.75"
1, 3.5" stud
1 spacer
2 nuts
All grade 8
How long is the spacer? Mine was snapped in half (no idea how you'd do that).
Old 01-08-2019, 12:49 PM
The stud goes in the #4 position and the long bolt goes in the #9 position.
The spacer goes on the stud for the lift bracket. As I recall you don't have a lift bracket. Right?
Old 01-08-2019, 12:51 PM
ironman's Avatar
ironman ironman is offline
Duh! It's as long as the one that you have snapped in half after you put the two pieces together.
Old 01-08-2019, 01:35 PM
Mudrig150's Avatar
Oh, I managed to find a lift bracket on the floor off my brother's 1450. Lucky me, I guess.
Tried that. Both parts when absolutely flying when it snapped off the stud and will be impossible to find.
Old 01-08-2019, 01:44 PM
Ok. Good. I can't measure it now. You can see it in the second picture, it's like 3/4" to 7/8" long. You can make it out of a piece of pipe.
Old 01-08-2019, 02:12 PM
You should update your fastener list.
Old 01-08-2019, 03:32 PM
Impossible to find...…
No surprise there!!
Old 01-09-2019, 07:14 AM
Leadslingingdaddy's Avatar
No surprise there!!
A or the???? Pure chaos....
