Thread Tools
Display Modes
Hi all,
I have a 1450 that's been sitting in storage for over a year. Tried to start it yesterday but no luck. Fully charged the battery and replaced the gas before checking for spark. I installed a new spark plug to no avail. What are the typical causes for no spark with this engine? Also, where can I get a diagram showing all cut-off/safety switches for this tractor? Don |
If it ran when you parked it then it's most likely a little corrosion on the points. I usually run a piece of fine grit paper between them and the tractors usually fire right up.
![]() Quote:
Thanks guys. I’ll try that.
Is there any where that I can get a diagram or list of all the safety/cut-off switches for my tractor? |
![]() Quote:
https://www.onlycubcadets.net/forum/showthread.php?t=22
