Old 07-23-2018, 12:12 PM
Don1450 Don1450 is offline
Default No Spark QL1450
Hi all,
I have a 1450 that's been sitting in storage for over a year. Tried to start it yesterday but no luck. Fully charged the battery and replaced the gas before checking for spark. I installed a new spark plug to no avail. What are the typical causes for no spark with this engine?
Also, where can I get a diagram showing all cut-off/safety switches for this tractor?
Don
Old 07-23-2018, 12:18 PM
If it ran when you parked it then it's most likely a little corrosion on the points. I usually run a piece of fine grit paper between them and the tractors usually fire right up.
Old 07-23-2018, 12:31 PM
Old 07-24-2018, 08:46 PM
Thanks guys. I’ll try that.
Is there any where that I can get a diagram or list of all the safety/cut-off switches for my tractor?
Old 07-24-2018, 08:51 PM
Here you go
https://www.onlycubcadets.net/forum/showthread.php?t=22
