Old 06-05-2017, 04:07 PM
alsparl alsparl is offline
Default An "Interesting" Accessory..."Any Thoughts?"
Had this advertisement come across our Facebook page a couple days ago and thought I would share. I understand the concept and application but not so sure I trust the mechanics of it all. I know MTD does something similar to this starting with the 1000/1500 series back in late 90s/early 2000s to try to make oil changes easier. I still am a fan of the magnet drain plug though.
Enjoy...but don't come yelling at me when the lever gets turned and you run your machine out of oil and lock it up.
http://www.ezoildrain.com/
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 06-05-2017, 04:15 PM
The lever has a lock on it. You have to either lift or press on it (I don't recall which) to get it to twist. It won't "accidentally" come open. Lots of equipment has them on it. It's a nice accessory for the hard to reach plugs.
Any good operator would notice oil pouring out of a motor anyway......
Old 06-05-2017, 04:18 PM
Looks like it has a spring loaded lock to keep it from accidentally opening, still not sure I would trust it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-05-2017, 05:25 PM
jimbob200521's Avatar
I actually like this idea, not that draining engine oil is that hard anyway. But as a convenience item, I'd give it a go.
-Ryan
Old 06-05-2017, 07:21 PM
The box store tractors come with an "easy-drain" plug and it's the worst thing to deal with. I like what Chevy did with my Cruze...the drain plug is hollow, so all I have to do is loosen it and out comes the oil.
Old 06-05-2017, 07:31 PM
IMO if I had an equipment company that required oil changes due to the frequency of use/high hours, I'd try it.
Old 06-05-2017, 10:00 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
2166 has 1
1- 1200 in pieces
1- 1864 in pieces
Old 06-05-2017, 11:21 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I like the idea... and i'm sure it works great!!
just not sure i trust it!
Jay
Proud owner of the following:
Old 06-05-2017, 11:38 PM
Originally Posted by Rescue11 View Post
2166 has 1
Yeah, all the 21 and 23 series combines did.
Old 06-06-2017, 10:48 PM
Jonathan, your response cracked me up. Working with the public as you currently do, and like I did at a dealership for a while, has probably taught us both never to assume someone is doing the right thing or everyone is an "aware or good operator."
Aaron
'83 782 #723927
'04 SRC621
****spec 24646
****s/n 2507913316
