Old 07-13-2016, 03:59 PM
riflemann riflemann is offline
Default Carb Adjustment Proceedure for Kohler Carb
I been frustrated by the carb on my Quietline 1200. The carb was rebuilt two years ago by an so called professional, but it never has been right since.
Now, when I go to accelerate the engine seems to flood and die. With the air cleaner assembly off, when I accelerate, I seen fuel coming out of the air intake of the carb. IF, I run the accelerator up SLOWLY, the engine slowly begins to increase RPMs, If I run the lever up fast, it stalls.
So, what does the top needle screw adjust? What is the side, angled screw for?
Is there a simple procedure?
Thanks!!!
Old 07-13-2016, 04:10 PM
Terry C's Avatar
Terry C Terry C is offline
Thanks!!!
Top screw is fast idle
Angled screw is low idle
In is lean, out is rich
When you change the one it will effect the other
Sounds lean to me.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-13-2016, 04:12 PM
RedHawCadet RedHawCadet is offline
The manual for the motor is in the resources section.
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 07-13-2016, 04:21 PM
SGragg SGragg is offline
Inactive Member
Wouldn't the Owner's Manual have that info?
Located here: http://www.onlycubcadets.net/forum/s...ead.php?t=4670
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 07-13-2016, 06:21 PM
twoton twoton is offline
Page 9
http://www.onlycubcadets.net/forum/s...0468#post30468
Old 07-13-2016, 08:01 PM
bocephus1991's Avatar
That information is basically a starting point to get it running, further fine tuning will most likely be needed.
Brian
