Old 06-25-2016, 08:05 PM
Default First hydro problem.
While mowing with the 1211 today I could smell hytrans, when I was done mowing I noticed the tunnel cover was wet as well as hytrans dripping from the lift bar for the rear lift. I pulled the tunnel cover and that's when I saw that one of the valves was leaking out of the small hole on top, I have a few valves sitting around I can put in until I have the extra cash to get them rebuilt. Since I have to take the rear fenders off I guess this will be the perfect time to add the 2 spool valve and front/rear ports, I guess next weekend I will mow with the 1050 since it's ready to go and nobodies buying it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-25-2016, 08:14 PM
I'm sure that you unlike some others have the talent to be able to replace the check valves. Nice to see someone that can figure it out.
Old 06-25-2016, 08:44 PM
whats the torque spec?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-25-2016, 08:49 PM
One F-rt should be enough.
Old 06-25-2016, 09:09 PM
Tim,
If you remove the cover that is not used for the gear drives ,you should be able to remove them.
Up to 534 and counting...
Old 06-25-2016, 09:28 PM
Tim,
It doesn't look like it will clear but either way the fenders need to come off to run lines.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-25-2016, 09:36 PM
Terry C's Avatar
Terry C Terry C is offline
I've gotten manual valves out with Lews method, never an auto.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
