Old 04-12-2016, 10:19 AM
JLM78 JLM78 is offline
Default Working on the 1572 #2
Started Work on The 1572 #2. Put new CV joint drive shaft, Rear brace. Found A crack in the frame .
Old 04-12-2016, 12:00 PM
Good job! Hope you can get the frame repaired easily.
Old 04-12-2016, 01:20 PM
Good catch on the crack. You should be able to V that out and weld it. The brace should also help prevent future problems. Looks like the crack started at the point that the lip on the bottom that is bent inwards stops on the frame.
Old 04-12-2016, 01:30 PM
Terry C's Avatar
Terry C Terry C is offline
Looking good
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-12-2016, 01:34 PM
Did a little more thinking about the cracked frame. You could use a piece of 1/4" flat bar stock drilled for the 4 bolt holes in this pic and weld it to the front mount for the brace kit. I outlined the area that I would reinforce in red and the place I'd weld in green.
Old 04-12-2016, 04:58 PM
longislandcubs longislandcubs is offline
Looking great, real nice work.
Old 04-12-2016, 06:18 PM
Thanks ever one. I have A guy come look at it to see if he can weld It .
Old 04-12-2016, 06:56 PM
Looking good Jason. Might want to do as Sam suggested but looks like horizontal crack too. Always a good idea to drill a hole at the ends of the crack, v it, and then do the welding.
Old 04-12-2016, 08:45 PM
aagitch's Avatar
aagitch aagitch is offline
As just suggested I would also drill a small hole at both ends of the crack before welding it. We had to do that when the frames would get cracks on our helicopters in the Marines.
Adrian
2072 (789513)
Old 05-01-2016, 06:33 PM
Got my frame welded up. As long as I was painting . I sanded and painting the hole frame. Not the best paint job but looks better then the one it had .
