Old 05-03-2010, 10:13 AM
Default Wix 51410 hydro filter
I replaced the gasket between the hydro and the rear on the 169 and it went well. I then tried to change the hydro filter with a Wix 51410 and the threads are different. I had two and tried them both. I had to put the used one back on until I get a new from Cub. Has anyone used a Wix for the hydro?
Old 05-03-2010, 10:21 AM
toyman's Avatar
toyman toyman is offline
That's the one I used on my 982 without any issue?
Original Member #54
Old 05-03-2010, 03:41 PM
aagitch's Avatar
aagitch aagitch is offline
I've got one on my 782.
Old 05-03-2010, 03:47 PM
labrati labrati is offline
I have a Fram I think on my 127... I have a question for everyone with leaks.. is it ok to use it while you are waiting on the gaskets? Mine leaks about 3-5 tbsp at most over a week period... I was thinking of topping off an mowing tonight.. needs it quite bad...
thanks
also, any value to a write up of changing these gaskets? Pictorial?
Old 05-03-2010, 04:24 PM
aagitch's Avatar
You should be fine.
Old 05-03-2010, 04:39 PM
labrati-
I'd get rid of that Fram filter ASAP...it's not a hydraulic filter, it's an oil filter. You can keep using it while you're waiting on gaskets though.
Old 05-03-2010, 05:20 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Fram makes one of the cheapest filters you can buy, I never use Fram for anything.
Pat Benner Haskell OK
Old 05-03-2010, 07:22 PM
Yeah, I noticed it the other day when I was looking for the leak... I'm a Mobile1 guy in our cars... what's best for the hydro? is there a >2micron that fits it?
Old 05-03-2010, 09:40 PM
ihnick's Avatar
ihnick ihnick is offline
why wouldnt the oil filter work? just curious?
Nick.
Old 05-03-2010, 09:44 PM
Amigatec's Avatar
The bypass valve in the bottom of the filter is different, I believe. Also micro size may differ.
