Old 09-30-2015, 09:04 PM
C&O2-10-4 C&O2-10-4 is offline
Default 109
I just picked up this CUB CADET 109 and the engine runs great, but I was told that it keeps breaking the drive shaft pin (engine end) to the hydrostatic unit. The relief buttons function fine and I can turn the shaft. What I do see is that the rubber ring connected to the shaft at the hydo end is distorted out of shape and wavy. Could that be the problem ?
Baldwindiesel
Old 09-30-2015, 09:15 PM
its probably breaking the pin because the slot is worn out in the driver coming off the engine.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-01-2015, 01:47 AM
kring kring is offline
if someone has used a 1/4" bolt instead of the correct pin in the driveshaft in the past, or it currently has a bolt instead of a pin, it will egg the driveshaft pin hole out and they will break about every 3-4 hours of use
127
129
1650
Old 10-01-2015, 05:47 AM
How about some pictures......???
Old 10-01-2015, 09:00 PM
Here's a drivehub I made. Notice the sides of the slot are smooth.
Old 10-01-2015, 09:52 PM
I agree with everyone else. Sure sounds like the hub is worn.
