Old 06-05-2015, 06:05 AM
adamjfeste adamjfeste is offline
Default Input pinion 108
I am having my input pinion shaft repaired because it was wobbled out. I brought it to a friend that has a lath. He is going to weld the hole shut, then turn it back down to 5/8" in his lath. wondering when he redrills the hole what size is it supposed to be from factory.
Also he is going to machine a new coupler. Also need to know what size the holes need to be for the coil springs m
Old 06-05-2015, 05:26 PM
cubby102's Avatar
cubby102 cubby102 is offline
I do believe it's 1/4 inch for the holes. If im wrong somebody will chime in and I'll need to weld and redrill mine
Old 06-05-2015, 07:28 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
yep , 1/4 inch
Old 06-05-2015, 07:52 PM
Here's one I just repair for a member here.
This one the hole was worn both out of round and also had over 20* rotational movement. Plus the end was worn down to .618
I did the weld repair and then indicated it in on my 4 jaw chuck with in a few tenths of a thousand. Concentricity is extremely important when dealing with gears. " Looks good" isn't good enough.
Edit,
I can weld, turn and drill the hole for $30
Old 06-05-2015, 10:43 PM
Mike in SD's Avatar
Mike in SD Mike in SD is offline
Jeff,
Just curious, how much do you get to do this type of repair? I have a few that need attention.
Thank you,
Mike
'62-O, 2-100, 71, 2-122, 2-123, 72, 127, 147, 108, 128, 149, 169, 2-1450, 582, 3-682, 2-782, 1811
1940 Farmall M, 1955 Farmall 300, 1967 Scout 800, Many Scout IIs, 1968 1200c 4x4
Old 06-06-2015, 06:57 AM
Just a FYI that part is still available new from Cub.
717-3073 Shaft, Reduction Drive $131.17
It also looks like Mid West Super Cub offers a replacement, this is from a catalog that is a couple years old so the price may be different today.
Replacement 12 Tooth Top Pinion
Shaft. This shaft is a direct replacement
for your Cub Cadet top pinion.
Made of superior material to original.
Prt No. TRG12 $78.75
Old 06-06-2015, 05:12 PM
Grampie Grampie is offline
I'm shopping myself for one, Today I got a price from a cub cadet dealer of $173.00 and NO, that's not going to happen!
Old 06-06-2015, 05:58 PM
dvogtvpe's Avatar
or just buy a good used one with the bearing and snap ring on it for $35 shipped
Old 06-06-2015, 07:22 PM
Mike in SD's Avatar
They just happen to be on sale this weekend from Midwest Super Cub for $50 plus free shipping. You can't hardly rebuild a wore out one for that.
http://www.midwestsupercub.net/
Thanks,
Mike
Old 06-06-2015, 07:28 PM
Originally Posted by Mike in SD View Post
Jeff,
Thank you,
Mike
I can fix them for $30. Since you have a few, a could offer a discount if they are sent at the same time.
Jeff
