Old 05-07-2015, 10:27 PM
breed-102 breed-102 is offline
Default Differential Lock?
What are some ways of doing this and has anyone had good or bad experiences with this? Thinking about pulling w/ my 102 but feel like I want to lock it.
Cub Cadet 102
Old 05-07-2015, 10:29 PM
cubby102's Avatar
cubby102 cubby102 is offline
Midwest super cub sells a spool for them iorc. Only other option is to weld the spider gears which I don't recommend..
Old 05-07-2015, 10:41 PM
blee128 blee128 is offline
I would pull it first my rear end is not locked and it pulls just fine
Old 05-07-2015, 10:43 PM
OK, now I know kits exist for this but dang $372 maybe I dont want to lock it that bad...
Cub Cadet 102
Old 05-07-2015, 10:44 PM
cubby102's Avatar
Balance the weight correctly and learn to manor your body.
Old 05-07-2015, 10:46 PM
Well the thing is I use mine back in the swampy areas in the woods as well and I was thinking that if it wasnt too hard to do, I would just lock it and then be able to pull and get through the mud. At this point I guess I'll just have to get something better than super lugs.
Edit *yes leaning way is good especially when there is no kill switch on the seat*
Cub Cadet 102
cubby102's Avatar
Get some good ag tires. If you lock it its also going to hurt your ability to turn...
Old 05-07-2015, 10:48 PM
Yup and I know some places where I can pick up an old crapsman or something to experiment with first before I do much internally.
Cub Cadet 102
Old 05-07-2015, 10:50 PM
thanks for turning me in the right direction!
Cub Cadet 102
Old 05-07-2015, 10:51 PM
cubby102's Avatar
I personaly wouldn't lock the rear at all if you plan to use it as a worker. If your back in the timber and swamp areas I highly doubt you will have a deck or mule drive attatched. Get a cheap harbor freight winch and build a quick attatch bracket...
