Old 08-30-2014, 10:10 PM
gdheck's Avatar
gdheck gdheck is offline
Default What are the adjustable carb. options for a Mag. 20?
I have a 2072 with a Mag 20 and fixed high speed mixture. I'm going to try to fix it once by putting in a throttle shaft bushing, carb kit, new throttle shaft if necessary, etc. What adjustable carb should I be looking for to feed the Mag 20?
Thanks
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 08-30-2014, 10:19 PM
dale c. dale c. is offline
I put a kt17 carb on mine but did notice a little power loss due to the smaller throttle bore
Old 08-31-2014, 07:49 AM
wally67's Avatar
wally67 wally67 is offline
I also put one off a kt 17 on my 20 mag I didn't notice any power difference but it does start better now. I thought both carburetors had the same bore 26mm if I remember correctly
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow.
Old 09-22-2014, 01:14 AM
gdheck's Avatar
Ok, I dug through the few spare carbs. that I have and the one that looks to be in the best condition is a 30. Is there any reasons why I should not use a 30 instead of a 26? Thought I would ask before I go to the trouble of rebuilding it.
Thanks
Old 09-22-2014, 02:09 AM
A #30 is too big. Stick with a #26.
