Old 08-25-2013, 03:36 PM
Mw2185 Mw2185 is offline
Default Cub cadet Hds 2185 transaxle
I'm a newbie here. Recently picked up a well used cub cadet hds 2185 and thought it a good idea to change the transaxle fluid and filter. After reading many posts I came to understand it is okay to run Rotella T 15w -40. I also installed a purolator pure one pl14670 filter which I cross referenced to be an alternative to the cub cadet filter 923-3014. Upon starting the tractor, it did not want to move in forward or reverse but let out an audible whine when trying to. The transaxle took about 6.5 quarts to reach the full level on the dipstick.
I am beginning to suspect the filter is not compatible so I plan on ordering the factory 923-3014 part, but I am really hoping I didn't do any damage to my transaxle.
Any thoughts from any seasoned veterans out there?
Old 08-25-2013, 09:55 PM
Just my 2 cents but I only use the OEM Cub filter, NAPA 1410 or Wix 51410. (Wix makes NAPA filters just remove the 5) as far as the oil I have heard people using Rotella in the older style Cubs but the HDS uses something else. First thing I would do is change the filter and if it won't move you may have a problem.
Old 04-18-2017, 09:48 PM
skydog skydog is offline
Iknow this is old, but if the crossed filter has a anti- drainback valve you can airlock it.
Old 04-18-2017, 11:58 PM
Old... yeah... nearly four years old. I'm betting he figured it out by now.
Old 04-19-2017, 09:11 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Well I don't care if the thread is 4 years old. I learned something. I've always heard, like Sam said, to use quality filters. Now I know why. Thank you for your post.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 08-04-2026, 10:33 PM
wbabadddog wbabadddog is offline
Cool
