Old 08-18-2013, 01:15 PM
mgrimm3 mgrimm3 is offline
Default Pics of 73
Some photo updates - not as much progress as I'd have liked...
Been running great for several days after some carb adjusting. Then it started leaking at the carb after I shut it down.
Thanks to jimbob200521 for the rattle mitigation idea. 5/16" was all I had so I'll redo it with smaller at some point.
Old 08-18-2013, 06:37 PM
Nice looking 73!
Old 08-18-2013, 06:57 PM
what mike said
Old 08-18-2013, 07:15 PM
Sweet oldie but goodie!
Old 08-18-2013, 07:31 PM
jimbob200521's Avatar
Looks great, glad it helped!
-Ryan
Old 08-18-2013, 09:06 PM
sawdustdad's Avatar
Nice 73! If the carb is leaking after shutdown, it's probably your carb float not floating enough to stop fuel flow, or something in the fill valve keeping it from closing all the way. Time to pull the carb to clean it up. Meanwhile, you can close the valve on the tank when you're done using the tractor to limit the leakage. I once had an entire tank of fuel leak out of one of my cubs while sitting in the shed.
Old 08-18-2013, 09:51 PM
Love those 73's. One of the rare ones. Very cool
Old 08-18-2013, 11:05 PM
I like it!!
Old 08-18-2013, 11:29 PM
That's a sharp 73!
Old 08-19-2013, 01:49 AM
Nice looking tractor
When you're done with it for the day, shut the fuel off and run it till it stops until you can get the problem corrected.
