Old 04-12-2013, 01:56 PM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
Default 149 trans service
I want to service the fluid in the trans of my 149. I also want take the rear cover off to check for moisture and junk build up. My questions are 1 I don't see a drain so the cover has to come off any way correct? And 2. Has anybody had luck reusing the gasket? They seem pretty expensive for a gasket to me. How about RTV or silicone gasket maker? Any thought or opinions are welcome. Thanks, Mark
1973 Model 149
42" Snow Blade
John Deere X360
John Deere 10 cu Poly cart
Squire Applegate 5HP recoil start
Old 04-12-2013, 02:18 PM
The rear cover does have to come off for the fluid to be drained. Take out the lower bolts first in an attempt to deflect the fluid down instead of all over the place.
Do not reuse the gasket. Get a new one. You'll be happier that way.
Old 04-12-2013, 02:38 PM
What Dan said. You can go to an auto parts store and buy some gasket paper and make the cover gasket. I did that for my 71 because I didn't want to wait for the dealer to get one for me. So far no leaks.
Old 04-12-2013, 03:17 PM
Ok, thanks guys. I ordered a new gasket. 14.00 plus 9.00 shipping. I have tried gasket paper before and haven't had much luck. Already enough leaks now!! Guess I just needed a push to do the right thing. thanks for the input. Mark
1973 Model 149
42" Snow Blade
John Deere X360
Old 04-12-2013, 03:41 PM
TommyK's Avatar
TommyK TommyK is offline
Mark, there is a drain plug underneath. If you can't find it, I can post a pic if you want.
Old 04-12-2013, 04:50 PM
i'm going to take the cover off but I would like a pic of the drain plug if you could post it anyway. Thanks, Mark
1973 Model 149
42" Snow Blade
John Deere X360
Old 04-12-2013, 05:02 PM
I would interested in seeing this.
Old 04-12-2013, 05:34 PM
I have one on my 128 also. Lower right front corner if I am not mistaken. You have to look for it. Mine was covered in old dirt and chaff.
Old 04-12-2013, 07:37 PM
Me too, never found one on my 149 or 169
Old 04-12-2013, 08:28 PM
I've never seen a drain plug on the rear of a cadet.
