Old 10-03-2012, 05:57 PM
ihc353s's Avatar
ihc353s ihc353s is offline
Default Cub Cadet 123, Axle Carrier leaks Oil!
Hi Boys,
at my fresh purchased CC 123, leaks the left Axle Carrier, it comes out at the Oil Seal Ring, and run over the Rim, and Tire. Now, i have to change the Oil Seal.
Last Week, i had the Transmission open, to change the Hydro Fluid, only 3 Liter Fluid was in it, not more, now, i know why!!! I changed the Hydro Filter too, and filled in, new Hy Tran Fluid, untill the Plug. The old Filter was painted Yellow, i think, it's the first one.
Does someone know the Size of the Oil Ring in the Axle Carrier, and how to remove the Retainer Ring, inside the Differntial Housing?
At Sunday, we have a Oldtimer Tractor Meeting in our Area, and i want to show my 3 Cub Cadets,
thanks, rgds Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 10-03-2012, 09:36 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
I have done this just this year in my 104... I believe although it is a Hydro, it is the same rear end in the Diff housing.... I took a pair of needle nose pliers and removed the C-snap ring on the end of the axle shaft and it slides right out, the clip comes out very easy... The oil seal you need is 721-0187. Not sure the size, but thats the item #.
Check out Pages 2-28 and 2-29 in this manual.... http://ccmanuals.info/pdf/1x4-5%20Service%20Manual.pdf
- Cory Sanderson
Old 10-04-2012, 06:14 AM
Hello Georg, ihcc is correct and also NAPA #9878 or National #471224. Nice looking 123. Good luck!
Old 10-06-2012, 02:44 PM
ihc353s's Avatar
Thanks for the Answers, it helped me yery much!
Yesterday, i removed the Transmission Cover, and the left Axle, i got the new Oil Seals from a Special Industrial Parts Shop here in our Area. The Ring have a Measurement from:
25,4mm x 38,1mm x 6,39mm,
Today, i changed both Oil Rings, and it's all OK again,
mfg Georg
Old 10-06-2012, 02:53 PM
ihc353s's Avatar
sorry, i forgot the Pics,
Old 10-06-2012, 02:55 PM
ihcc104's Avatar
Cool! Glad to help! Nice looking 123!
- Cory Sanderson
Old 10-06-2012, 03:44 PM
TheSaturnV's Avatar
Well done Georg, I really like your 123.
Old 10-06-2012, 10:07 PM
I totally agree!
Old 10-07-2012, 08:32 AM
I totally agree!
Me too Georg!
