Old 09-11-2012, 03:26 PM
Kellhammer Kellhammer is offline
Default Battery not charging
My Cub cadet 1250 hydro is not charging the battery ,or it is, but something else is going on. I asked this same question on another forum and someone suggested it could have something to do with the electric PTO clutch.
I had tested the electrical system and it seemd to be doing what it supposed to. I have not tested the PTO clutch which works just fine.
Heres a typical way the problem shows itself. A brand new battery with a full charge , start up and cut grass fo a hour , turn off and minutes later attempt to restart but battery is dead. I have replaced the battery every year for the last five years.
Old 09-11-2012, 04:37 PM
teejk teejk is offline
I'd suspect the switch...get it started and "wiggle" the key as you watch the amp meter. I had that problem once.
Old 09-11-2012, 05:28 PM
Just checking to see, you did check the stator output with a multimeter?
Old 09-12-2012, 08:35 AM
I will check the switch, Yes, I checked the electrical output, it was right on.
Old 09-12-2012, 09:17 AM
This may help you.......... Charging Test
