Old 07-08-2012, 09:44 PM
JayBrd's Avatar
JayBrd JayBrd is offline
Default Ignition Battle help
Sorry I haven't been posting too much for quite some time but work has me in a state of never ending busy
But I am now in that "should've did a re-build" time of ownership I think.. A while back the 682 started shutting off on me, and not wanting to restart. Sometimes it would do it with the pto on only, then only with lights off. I ordered a new ignition switch from one of the local dealers. I know I have 2 wiring diagrams show different wiring for the IH and CCC models. When he stated that it was the same part number I kind of wanted to not go with that. I looked into it and sure enough it is...Well I went to get it Friday and sure enough, same prong layout ect. As soon as I put the wire plug on she turns over and lights are on?????????
What am I missing here???
Jay N.
Eau Claire, WI
RED 82 Series...
Old 07-09-2012, 06:19 AM
The Ignition Switch for all serial number ranges for the 682 is 725-3021.
IF everything on your 682 is factory original, then it should work.
Old 07-09-2012, 07:01 AM
JayBrd's Avatar
Part number is a match..
The plug which I thought was melted on one corner is in fact completely missing in the center. I should have time to look further into it this afternoon. I am hoping that the connectors "missed" and went between prongs on the switch and made contact with each other is all it is. I am going to call the NAPA store later to see if they would have the right one to replace it, if not will order thru the CC dealer I guess..
Thanks Roland
Jay N.
Eau Claire, WI
RED 82 Series...
Old 07-09-2012, 07:13 AM
If the Molex plug connector on the Ignition Switch Harness is compromised in any way, then any combination of issues can arise.
Old 07-19-2012, 05:09 PM
JayBrd's Avatar
Back up and running Thanks Roland....
Spent the odd and rare day off mowing, then tossed the plow on the back and turned last years food plot. It is for sure dryer than a popcorn fart up here! was running 6" or so deep and bone dry!
Jay N.
Eau Claire, WI
RED 82 Series...
