Old 03-24-2009, 07:01 AM
rfrank's Avatar
rfrank rfrank is offline
Default Brought the 149 home Finally
So I went to my brothers this weekend, to get the new to me, 149. The tractor wouldn't start, as the replaced ignition switch was the wrong one. So we jumped it from the coil to the gen and the battery and it worked well. Got it home and was doing some looking into, and assessing the damage. Well I need 2 pulleys for the mule drive, two belts for mule and deck. 2 belts for the #1 tiller. a Rear cover gasket as the one that was on it started leaking when I mounted the tiller gear box. DOUh. the tires that are on it ar 10.50s which explains why they rub on the 42in deck. so Ill put my 8.50 on it for summer mowing and the 10.50s with chains for winter use. the hydro release lever is borken and the hydro fan as well. Good news is that she doesn't smoke, and the hydro fluid looked great. So with that well see when the parts come in, how she runs. I tried to get her to run around the yard but it wouldn't run at full throttle with the hydro fully engaged to the fasted speed even after warmed up. thought it might be the lack of a battery. the points looked good but I didn't check timing yer. that little cover is a bugger to get back on. Will replace with Allen Heads soon. There ya have it.
Old 03-24-2009, 09:52 AM
Bob Balk Bob Balk is offline
The points cover is a pain! While I had the engine out I filed a small recess in the frame so I can get the bottom screw in and out. I don't think it will be a stress point for the frame and should make setting the points much easier. Allen heads are a good idea!
Old 03-24-2009, 12:36 PM
Glad you got your 149 home. Please post some pics, when you get a chance.
Old 04-05-2009, 07:14 AM
rfrank's Avatar
Hopefully there are threee images of my 149 below if not then Ill try again. Tinker tinker Tinker
Old 04-05-2009, 07:21 AM
rfrank's Avatar
First pic is the 23 x 8.50s painted, second pic is the 23x10.50s unpainted as I received them. The third has a lttle red on the front nope not IH Red, thats Bob red,(blood) oops. Super glue got to love it.
Old 04-05-2009, 11:30 AM
rfrank,
Nice lookin 149 you have.
I really like mine.
Old 04-05-2009, 11:38 AM
Great looking 149 rfrank! Thanks for the pics.
