Old 04-30-2012, 12:30 PM
Ottis Ottis is offline
Default 582 Command Swap? Need the FACTS.
Has anyone nailed down exactly what is required to swap a command into a 582 or 82 series tractor yet? I know there are multiple posts questioning the Command swap but none have clearly defined answers.
Does anyone have all of the dimensions for a command motor by chance and or all of the dimensions for the stock briggs opposed I/C 16 twin?
I have a vanguard in my 582 now but have another one that is sitting in the garage begging for a repower. I like the vanguard but there is so much more out there for the Commands.
Can we get this set in stone? Parts required? Dimensions? Etc.?
Help would be greatly appreciated. By me and others I am sure.
Old 04-30-2012, 01:13 PM
cubs-n-bxrs's Avatar
I have done this swap and is not to bad of a job. Check out this thread.
http://www.onlycubcadets.net/forum/s...ad.php?t=12198
The drive shaft and the exhaust are the biggest challenges. I ended up using the whole wiring harness from the donor tractor.
Old 04-30-2012, 04:57 PM
582 is a little different than a 682. I have done this exact swap...check out my website in my signature line.
Old 04-30-2012, 07:00 PM
Matt
Checked out your site, pretty cool. What did you use for an adapter for the clutch on the CH? Let me know if you want to make the 18 into a 22 I have a good carb off a CH22. Playing with the idea of putting my spare CH22 into a 71, Yeah I know the frame will need some serious surgery but that’s why they make welders.
Old 04-30-2012, 08:13 PM
Tater305's Avatar
Tater305 Tater305 is offline
look up some of the pulling supplier websites they sell the hub that bolts to the command so you can bolt the driver to it. its actually really easy to do alot of pullers run the commands so there is alot of people who have done this, you also have to drill new holes for the command in the motor plate and shim the motor up, maybe new choke and throttle cables too but you should be able to use the factory wiring just have to move some wires around
Old 04-30-2012, 11:12 PM
Vince_o Vince_o is offline
I got mine from MWSC
Old 05-01-2012, 07:08 AM
I made mine because I needed a pulley to eventually add a pump for hydraulic lift.
Old 05-01-2012, 09:42 AM
Looks good guys, thanks for the info.
If I understand right; just some .469 spacers under the command and I should be ready to go? Aside from the command driver, etc. for the clutch set up?
Looks like I will be ordering a command in the near future.
