Thread Tools
Display Modes
I've been waiting forever to have the extra $ to purchase a Tiny Tach. I was finally able to order one 2 weeks ago.
I finally got a chance to work on the 1450 over the weekend. I set the throttle at 3600 RPM no load with the tiny tach. I noticed when I engage the PTO with a 44A deck mounted, the RPM (at WOT) would drop to around ~3000. Does this sound about right? If one has a tach available - would it be harmful to allow "room" at the top end for the extra 600 RPM? Ex. set the throttle at 3/4 WOT for 3600 RPM, so that with deck engaged the WOT would permit the extra 600 RPM? Thanks for any thoughts, -Calvin |
RPM's dropping under load seems perfectly normal for any size engine. I'd not exceed the max RPM under any load condition.
John
![]() Quote:
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
I think the governor is to attempt to keep it from dropping TOO low, and from over-revving.
Think of your car going up a steep hill pulling a trailer with the cruise control on. At some point, it's going to start slowing down in RPM even with cruise on, unless it downshifts, or unless you have a very powerful engine. John
you may want to adjust your carb a little while underload. My 1450 WOT is no load is 3600rpm, turning on the 44A deck drops it to ~3500 rpm. While moving and cutting average grass height its about 3400-3450 rpm's. If the grass is very high and heavy I have seen it drop to 3200rpm's (she is working hard at this point)
Either way a few data points for you |
Any pictures of the tach installed?
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4. |
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]() ![]() |
I'm sorry - I did a cheesy install so I could move it around if I had to - nothing fancy at all - although I'm very happy with the product.
-Calvin |
