Thread Tools
Display Modes
This must be the month for the trunion repair. I removed the seat and fenders and am at this point of the repair. When welding up the corners is the wet rag the best option or should a heat sink be used as well? Also any other pointers would be a great help.
Steve 1450 QA42A Thrower 44A Mower |
Steve, now that you have it off you can weld it up or if you've put it back on the wet rag will work.
Duke, it looks like it's still on the tractor
![]() Do the wet rag thing around the bottom to help with over heating.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Exactly and do small welds, then some filing, then some welds. That will help keep down the heat. That looks just about the same as my 1250 was when I fixed it.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
wet rag works good. i live in north wisconsin and used packed snow around it. worked great. it doesnt take much to fill them in. i hope you got new springs for it too. its a must in my opinion. good luck
And end caps.
Here is some more info if you don't already have it:
McMaster Carr carries the shims. I used .005 http://www.mcmaster.com/#standard-shims/=gepzon 5/8" ID for the damper plate assembly shims 1/2" ID shim for the Cam assembly control plate plate.jpg plate2.jpg bushing.jpg
Yes, it's still on the tractor. I'll take care not to over heat with a wet rag and even use the snow that "cmatthew" recommended.
Got it DWayne, small welds, file, then small welds, file some more. If it looks good when I'm done I'll post a picture.
![]() Quote:
