Old 05-19-2011, 09:07 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
Default new 100
i just bought a 100 and i will try to get pics later but it supposedly has a new rebuilt s/g on it and it has the terminals for a car battery so i put a old car battery and the only thing i saw was sparks and the nasty burnt smell this thing is supposedly has been setting for a very long time so my question is what is the biggest battery a starter generator handle and can you get a rebuild kit for the starter
o and ps are these things supposed to be really easy to turn over it doesnt seem anything like my 1650
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 05-19-2011, 09:25 PM
First thing to do would be to check over ALL of the wires on the 100. Seems you have yourself a short someplace, because just by hooking up a bigger battery isn't going to make sparks fly as long as it's 12 volt.
And your second question about starting slow, all of mine do compared to the newer model tractors.
Old 05-19-2011, 09:31 PM
well i never got to hear it crank and the sparks came from the inside of the starter generator
75 Cub Cadet 1650
64 Cub 100
Old 05-19-2011, 10:50 PM
So you just hooked up the battery and the sparks came out of the S.G. ?
Old 05-19-2011, 10:57 PM
scleve scleve is offline
Did it try to start the engine? Are the insulators on the s/g post cracked? You can get repair parts for them.
scleve
Old 05-19-2011, 11:21 PM
i just got the cub so i put my battery in it 650cca maybe a bit much but it is all i had i turned the key and pushed the start button nothing so i got out my test light and seen i was getting power to the s/g so i pushed the button again and thats when i saw the spark and then the burnt smell
75 Cub Cadet 1650
64 Cub 100
Old 05-20-2011, 06:33 PM
I think you need to check all your wires. Find a wire diagram and go through everything. Only thing I can figure is something is connected wrong. Hopefully one of the others with way more smarts than me will chime in.
Old 05-20-2011, 10:14 PM
found the problem the sparks were coming from a brush wire touching the housing because the brush was i sideways
75 Cub Cadet 1650
64 Cub 100
