#31
Cory
I guess he lost the wire bail. A few things... how clean is the tank and the carb? Try to oil up the bore before you try to get it running, it sat for a long time... Looks like you have some work to get it running. Keep us posted
#32
![]() Quote:
How would u suggest oiling up the bore? literally putting oil in it? - Cory
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
#33
Not too much a few squirts should do it...
#34
I'd take the plug out and spray some PBlaster around the bore as you turn the engine over by hand. Can't hurt!
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
#35
Most of the time I have found that the spindle get stuck in axle making it not steer. I would try that first.
#36
![]() Quote:
#37
Be care as the collared spindles are not easy to find.
#38
I will try my best. I need to go online and find a diagram as this is my first run-in with a collared setup. Obviously they weren't a good idea or they would have kept them and not replaced it with the other system.
#39
glad you finally got a reasonable second o! looks like a fun project
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! ![]() |
#40
![]() Quote:
