Old 02-01-2013, 08:23 PM
Cory
I guess he lost the wire bail.
A few things...
how clean is the tank and the carb?
Try to oil up the bore before you try to get it running, it sat for a long time...
Looks like you have some work to get it running.
Keep us posted
Old 02-01-2013, 09:10 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Cory
A few things...
Keep us posted
The tank is clean as a whistle and the carb was not bad either. The top throttle linkage on the carb is very loose though, Ill have to see if someone has a junk one with a good throttle arm.
How would u suggest oiling up the bore? literally putting oil in it?
- Cory
- Cory Sanderson
Old 02-01-2013, 09:19 PM
Not too much a few squirts should do it...
cubfixer's Avatar
cubfixer cubfixer is offline
I'd take the plug out and spray some PBlaster around the bore as you turn the engine over by hand. Can't hurt!
John
Old 02-01-2013, 10:10 PM
cnixon's Avatar
cnixon cnixon is offline
Originally Posted by ihcc104 View Post
True, but the steering is locked up, wont turn, not sure if it is just the linkages or if it is the steering box.
Most of the time I have found that the spindle get stuck in axle making it not steer. I would try that first.
Old 02-01-2013, 10:17 PM
ihcc104's Avatar
Yes sir, I think you are correct, the steering wheel turns, I just need to try freeing up the spindles.
- Cory Sanderson
Old 02-01-2013, 11:05 PM
cnixon's Avatar
Be care as the collared spindles are not easy to find.
Old 02-01-2013, 11:48 PM
ihcc104's Avatar
I will try my best. I need to go online and find a diagram as this is my first run-in with a collared setup. Obviously they weren't a good idea or they would have kept them and not replaced it with the other system.
- Cory Sanderson
Old 02-02-2013, 08:34 AM
cadzag72 cadzag72 is offline
glad you finally got a reasonable second o! looks like a fun project
Ian
Old 02-02-2013, 09:16 AM
ihcc104's Avatar
Thanks Ian!
- Cory Sanderson
