Old 04-11-2012, 05:19 PM
If that isn't a deep sump oil pan, you have a K241 and not a K301. Somebody might have turned that into a 105 at some point.
Old 04-11-2012, 05:38 PM
Sugarmaker's Avatar
Doug,
This 125 is really looking all cleaned up and shiny! Nice work!
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 04-11-2012, 07:44 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
pic of the tag and the pan. would of the flywheel cover fit other kohlers?
Doug
Original , 100 , 125 , 582
Old 04-11-2012, 07:58 PM
4SPEED's Avatar
more pics
the shim is a machine shim 18ga. it took some doing to get it in , but shes tight now. the only play in it now is the bearings in the wheels. I'll change them out when my try ribs get here.
and a before and after of the wheels and tires.
Doug
Old 04-11-2012, 08:07 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Nice!
You do really good work ...and quickly!
That tractor really has spent some time pulling things, to hog out that towing pin hole, hasn't it?
You're really rocking in that thing. I bet that 125 is glad it landed in your shop :-)
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-11-2012, 08:55 PM
EricR's Avatar
EricR EricR is offline
Very nice job there Doug!
Yeah when I get around to fixing 102-D I'm going to have to do the same with the front end as you did as the spindles are VERY sloppy and you just gave me the perfect fix, thanks.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 04-11-2012, 09:34 PM
jbrewer's Avatar
Default Spindle
How did you fixture your axle to make sure you drilled the oversize hole exactly parallel to the original bore?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 04-11-2012, 09:35 PM
Coming along nicely Doug.
Old 04-11-2012, 09:38 PM
more pics
Your progress looks great!!
I see the bolt is now in place holding the front axle.
I hate to back you us a step, but, I have seen others just tighten that bolt to take out the slop of the frame to axle fit.
Without the shim, the axle/frame joint will be slightly stronger.
Old 04-11-2012, 10:18 PM
Looks like a nice job on the 3 point.Your motor has a flat oil pan so it is a K241
