Old 04-10-2012, 09:26 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
Default 125 , Things Im Working On (Fixing)
I think I found some more of the PO's cob work. I have tons of slop at the pivot point. I was going to shim it but found this piece (looks like) drive shaft in it with a 1/4" bolt holding it in. Id think it should be a bolt. right?
the spindels have play in them too. Im going to get some 1" shim bushings and drill the holes in the axle to fit the shim and press them in. that should take out the play in them.
I'll do the same to the rear hitch , the holes in the frame that the rod rubs on. the frame holes are egg shaped. might just weld them and re-drill the holes and make a new rod.
I installed the spring assist , thats a tight fit.
new pump filter , as it looked like it was put on with channel lock pliers.
new fan and should installed
Doug
Original , 100 , 125 , 582
Old 04-10-2012, 09:36 PM
4SPEED's Avatar
a few more pics, I know how we love pics.
by the time im done fixing things , this cub will have all new paint on it . lol
Doug
Old 04-10-2012, 09:42 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Looks like progress, Doug! Keep it going, I need the inspiration to get my 125 split and clean up my hydro. I want to see how your spindle slop repairs go, too. Always wondered how to shim or fix the slop in the stems...
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 04-10-2012, 09:48 PM
The filter was so tight on my 125 that I bent my filter wrench. I had to borrow the spring one from a friend to get it off. I thought for sure my long handle rachet was going to bust.
Old 04-10-2012, 09:50 PM
cub1450's Avatar
cub1450 cub1450 is offline
That front axle pin is factory I don`t think they started putting bolts in them until the 82 series .
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 04-10-2012, 09:53 PM
4SPEED's Avatar
I did the same here. I posted this a week ago. it worked good.
http://onlycubcadets.net/forum/showthread.php?t=16948
Doug
Old 04-10-2012, 09:57 PM
4SPEED's Avatar
OK thanks , good to know. but Id think a bolt would work better
Doug
Old 04-10-2012, 11:06 PM
Thanks for the pics, Doug!
Old 04-10-2012, 11:37 PM
cub1450's Avatar
They do.
Thats what all my cubs are getting when I get around to it.
Jed
Old 04-11-2012, 06:34 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Good work already! It's always "interesting" to observe shadetree work... less interesting to fix it sometimes!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
