Old 03-02-2011, 02:13 PM
Mlamar Mlamar is offline
Default Wires
Hey JaysNJcub127
If you can give me a day I can post pictures of an actual headlight harness from one. I make the harnesses from the original factory wiring dimensions and have a few of the old ones at home. I can post pictures as well at measured lengths of the wires for you. On the headlight wiring I use 12 ga. yellow wire. The ground terminal for the voltage regulator bracket bolt is a 1/4" ring terminal.
Old 03-03-2011, 08:22 AM
nikster's Avatar
nikster nikster is offline
Nik:
I would look at your Ag or Farm Implement Stores and/or Suppliers (ie: TSC).
Ah, called Farm & Fleet & the gal told me I can get them.
Thanks,
Nik
Old 03-03-2011, 09:14 AM
Default Photo
The hot wire that runs from bulb to bulb is 13" from terminal tip to terminal tip. The ground has two wires about 8 1/2" each in length.
Old 02-26-2013, 08:59 PM
dieselman1 dieselman1 is offline
ThIs is just what i am looking for thanks guys i just bought two head lights today and i was wondering how to wire it up.
