Old 03-01-2011, 10:40 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Headlight Harness
Can someone post a pic up of a headlight harness on a 73 / 127.
I need to make one and wanted to see an original one so I can duplicate it.
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 03-02-2011, 05:58 AM
This should help you.... Diagram. Scroll down to the 1x6/7 Series.
Old 03-02-2011, 06:04 AM
Default Thanks
Thanks I have that but looking for a picture of the actual harness so I can duplicate it to factory look. The wire that were on there were put together with wire nuts!!!! Yikes.
1969 Cub Cadet 127
#2 IH cart
48" deck
42" Front Blade
IH wheel weights
Old 03-02-2011, 08:21 AM
First, let me say, that I do not own a model within the 1x6/7 series of Cubs. Based upon what I have seen on other series of Cubs, I would venture an educated guess, that there is no "headlight harness". I suspect, that there is a single 14GA Yellow Wire that connects to each end of the Main Harness at the purple wire connectors, as it travels through the "tunnel" area..
I would simply get some 14MTW GA wire in Yellow and a few terminal connectors, an inline fuse holder, a light switch, and wire up as indicated in the Wiring Diagram.
Now, it is not to say, that one can not find the actual wire that IH made for their lighting kit but I would guess this maybe a tad difficult.
One could try the Sponsors above and place a Want Ad in the Classified Section to see if any can be found.
Old 03-02-2011, 09:19 AM
gcbailey's Avatar
gcbailey gcbailey is offline
I'd go with Roland on this one.... The light harness I got for my 127 was as described by him. I've saw a few more harness pictures looking on flickr and they are all the same way.
Gary
Old 03-02-2011, 09:41 AM
nikster's Avatar
nikster nikster is offline
Since this post is related to lights, where does one BUY the rubber type cushion for the lights? Can't seem to find them?
I took my headlights out to replace them & the rubber gasket that
I'm assuming it's to absorb vibration, & it fell apart in itty bitty pieces of garbage.
Any suggestions if those gaskets aren't available?
I would think that they are IMPORTANT?
Thanks in advance,
Nik,
Old 03-02-2011, 09:54 AM
Default Picture
Picture Gary!!!! Please!!!
1969 Cub Cadet 127
#2 IH cart
48" deck
42" Front Blade
IH wheel weights
Old 03-02-2011, 12:33 PM
Nik:
I would look at your Ag or Farm Implement Stores and/or Suppliers (ie: TSC).
Old 03-02-2011, 01:03 PM
Sminkey
Guest
Posts: n/a
Here's a couple pics from my 147, same as 73, 127 I think. Hope this helps ya out.
Old 03-02-2011, 01:21 PM
gcbailey's Avatar
These are the only ones on my laptop... let me know if you need other angles and I'll snap some later.
Gary
