Old 04-23-2011, 05:16 PM
thetucks thetucks is offline
thank you very much guys for all your help. i did check everything that you guys suggested. but I did find the problem. when I put it back together I added a washer between the teaser spring and the clutch plate. for some reason that wouldnt allow the teaser spring to uncompress all the way releasing pressure. I took it all apart about 8 times total before I figured that out. took that washer out and now it works like its suppose to. thanks again.
Old 04-23-2011, 07:43 PM
Glad to hear you got it figured out.
Old 04-23-2011, 09:31 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Originally Posted by thetucks View Post
opps forgot the pics,lol
This is what mine looks like. first pic is engaged , next 2 are not . I think you have a problem with how something is spaced on your drive shaft.Did you put a different throw out bearing in that is a diff length. The travel that you have looks the same as mine . maybe put a spacer in the wrong spot.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 04-23-2011, 09:34 PM
jeff k.'s Avatar
oops, for got to check page 2 before posting.looks like I was on the right track though.
Old 04-23-2011, 10:14 PM
william1041200's Avatar
looks like you need a new teaser spring!
Old 04-24-2011, 10:54 AM
jeff k.'s Avatar
That whole tractor needs some TLC. It blows smoke both out the muffler and the head.Need to save some $$$ before I tackle it . so for now it's going on the back burner.
