Old 04-22-2011, 11:01 PM
thetucks thetucks is offline
Default clutch reinstall questions
Hello I am in the process of rebuilding my cub cadet 100. I have completley took every nut and bolt apart and stripped and painted it. im in the reassemble stages. I was in the process of putting the clutch back together and ran into a problem. when you push down on the clutch/brake pedal the clutch lever hits the steering box. it dont push on the clutch bearing enough for the teaser spring to release. so I took it all back out and turned the clutch bearing around so the little bump out is facing the back of the tractor. now the clutch lever contacts the bearing and releases the teaser spring like its suppose to. but I dont know if this is right? I thought the bearing is suppose to have the bump out facing the front? any help you can offer on this would be great. thanks.
Old 04-23-2011, 09:19 AM
TommyK's Avatar
TommyK TommyK is offline
The bump out on the throwout bearing should be facing the front of the tractor, or the motor, like you had it originally. Did you adjust the clutch linkage? On my 108 the clucth/brake pedal is supposed to have a free movement of approximately 9/32 of an inch.
Old 04-23-2011, 09:22 AM
yes sir i did. but it didnt matter what I adjusted it to, the lever hit the steering box before it pushes the bearing back.
Old 04-23-2011, 09:39 AM
Pictures might help with this. I can't figure out why it would be doing this.
Old 04-23-2011, 09:47 AM
ok here you go. the first pic is with the pedal not pushed and the second is with it pushed down. you can see the lever is hitting the steering and its barely pushing the bearing. the teaser spring is not even uncompressed to let the clutch seperate. this is with the bearing facing forward like its suppose to.
Old 04-23-2011, 09:48 AM
opps forgot the pics,lol
Old 04-23-2011, 10:38 AM
It looks like it is just barely catching the edge. Do you think the arm or mount maybe a bit tweaked? Also when putting my steering shaft back onto my 128 I noticed it has some room for movement. I wonder if you can loosen the shaft housing and try to move it over a bit?
Old 04-23-2011, 11:59 AM
I have thought if that also. I thought about shaving the arm where it hits but it still would not be enough to push the bearing enough. I also tried to move it over a bit but then it dont line up with the motor. I really appreciate all your thoughts.
Old 04-23-2011, 03:10 PM
william1041200's Avatar
Did you replace anything with new or new to you parts? shaft, steering box? I am not very familiar with a 100, and don't know if its safe for me to compare to my 104 setup in similarity. Hope I can offer help, but unsure.
Old 04-23-2011, 03:14 PM
Is the top throwout arm pivot mount made with an offset? If so, would it help to flip it over? I think The entire driveline on my 104 is offset to one side, and steering box is offset to other side for clearance.
