Old 07-12-2009, 07:24 PM
jasoncald1 jasoncald1 is offline
Default 125 hydro help
hello how do u add oil to the hydro unit im wanting to do a oil and filter change can anyone put the right info of doing so on me please
Old 07-12-2009, 07:29 PM
67hydro's Avatar
67hydro 67hydro is offline
On the tractor there is a plug in the rear cover plate,remove it and fill from there,fill all the way until it starts to dribble out!! On the hydraulic unit to lift the implements there is a plug you fill from on the side/top.Im pretty sure your talking about the tractor,because you said filter,but figured Id add the hydro unit for the lift also!!!
If it was me Id remove the rear cover plate,get a new gasket and clean all the gunk out in the bottom of the tranny,IF there hasnt been regular filter and oil changes.
Jason
Jason Davis
Old 07-12-2009, 07:32 PM
RPalmer's Avatar
RPalmer RPalmer is offline
Go to your rear end. On the differential you will see a plug with a square the size of a 3/8" drive ratchet. Remove the plug and add Hytran till it's to the opening of the plug. All done after you put your plug back in.
Old 07-12-2009, 07:34 PM
RPalmer's Avatar
67hydro,
You beat me and my one finger typing.
Old 07-12-2009, 07:45 PM
Hey jasoncald1,
here are a couple of pictures of what we are talking about.
Like 67 hydro said get a new gasket and remove the cover to drain and clean it out, I have never seen one that didnt have at least a little sludge in it.
Here is a picture of the cover plate with the fill/ check plug.
Old 07-12-2009, 08:19 PM
ajgross ajgross is offline
Inactive Member
FYI, the "sludge" in the trannys is normal. The hy-tran absorbs water and forms that sludge. That's one of the reasons we really recommend hy-tran for the rear ends.
AJ
Old 07-12-2009, 08:57 PM
thanks for all the quick help it probably hasnt been changed in over 10 years i found it growed up in weeds this spring the hydro is real jerky move lever just a little and man does it take off prob wont fix it with oil change i think i need some adjusting or something on it got a hydro leak somewhere on bottom circle the size of a cd runs out every time i use it
