125 hydro help
hello how do u add oil to the hydro unit im wanting to do a oil and filter change can anyone put the right info of doing so on me please
On the tractor there is a plug in the rear cover plate,remove it and fill from there,fill all the way until it starts to dribble out!! On the hydraulic unit to lift the implements there is a plug you fill from on the side/top.Im pretty sure your talking about the tractor,because you said filter,but figured Id add the hydro unit for the lift also!!!
If it was me Id remove the rear cover plate,get a new gasket and clean all the gunk out in the bottom of the tranny,IF there hasnt been regular filter and oil changes. Jason |
67hydro,
You beat me and my one finger typing. |
Hey jasoncald1,
here are a couple of pictures of what we are talking about. http://i286.photobucket.com/albums/l...drowork009.jpg Like 67 hydro said get a new gasket and remove the cover to drain and clean it out, I have never seen one that didnt have at least a little sludge in it. http://i286.photobucket.com/albums/l...ors/149007.jpg Here is a picture of the cover plate with the fill/ check plug. |
FYI, the "sludge" in the trannys is normal. The hy-tran absorbs water and forms that sludge. That's one of the reasons we really recommend hy-tran for the rear ends.
AJ |
thanks for all the quick help it probably hasnt been changed in over 10 years i found it growed up in weeds this spring the hydro is real jerky move lever just a little and man does it take off prob wont fix it with oil change i think i need some adjusting or something on it got a hydro leak somewhere on bottom circle the size of a cd runs out every time i use it
| All times are GMT -4. The time now is 01:25 PM. |
