Old 04-01-2011, 02:34 PM
christopher peregoy christopher peregoy is offline
Default 149 key switch problems.
149 key switch problems. Does anyone have experience with changing to push button start switch?
Old 04-01-2011, 06:59 PM
YES.....but why would you want to go back to that type of system..???
Old 04-01-2011, 07:38 PM
It’s my mother’s tractor and she has trouble putting the key in and often leaves it in the on position and drains the battery. She loves cutting with the mower and I would help her keep going.
Thanks Chris
Old 04-01-2011, 08:05 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Would the wiring diagram from the O work? It shows the push button.
http://www.onlycubcadets.net/forum/showthread.php?t=35
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 04-01-2011, 09:47 PM
jeff k.'s Avatar
Originally Posted by Wild Bill View Post
The electric start Original, also had a key. The key turns on the ignition circuit.
The push button engages the starter/generator....just like turning the 149's key to 'start'.
If you forget to turn the key off on an Original, you drain the battery, just the same as you would on a 149.
They could put a push pull or toggle switch in place of the key .
Old 04-01-2011, 10:23 PM
westofb's Avatar
westofb westofb is offline
Thanks Chris
No matter what system you have the push button or the key start, you will have to turn it on and off to energize the ignition, with the push button that would be a separate toggle switch. If she forgots to turn it off, does she park it and let it run until it dies (out of gas)! Your mother ought to be old enough by now to learn to turn things off when she is done with them!
Old 04-01-2011, 11:14 PM
Default thanks
Thanks I will put in a toggle before switch, she is also old enough to forget to turn things off . Thanks chris
Old 04-01-2011, 11:31 PM
westofb's Avatar
Okay...lol
Jeff
Brookfield, MO
________________
Old 04-02-2011, 08:18 AM
Just a thought,
Possibly put a string on the key and have her put it around her wrist or neck like a necklace then she will not forget to turn it off.
Old 04-02-2011, 11:32 AM
hermzk hermzk is offline
Might be looking at this in a slightly different way, but how about an LED or any 12v indicator light? Would at least be a reminder the ignition switch is still turned on, and be a fairly easy task to accomplish.
