Old 12-16-2021, 11:37 AM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Yes sir, sleeved back to STD.
All told, the engine now has NOS valves, NOS piston & rings, NOS rod, NOS crankshaft, new SKF bearings, NOS head gasket, NOS plug wire, new points & condenser, new plug (of course), a rebuilt Carter 26 carburetor to replace the crummy leaky Chinese one that the tractor came with, and then the boring stuff like gaskets, seals, air filter, and things like that (all new obviously). Had the gas tank cleaned, a small crack brazed, and pressure tested by a local radiator shop. New muffler. Fixed the ruined threads on the exhaust elbow by cutting them off and welding on the threaded portion of a 1" pipe nipple (as finsruskw suggested on here in the past). Lots and lots of painting...
Oh, and the S/G issues I had a year ago now have been fixed as well - after soldering a new post onto the field wire (if I remember correctly) it charges correctly.
There were a number of odd/frustrating issues I ran into along the way, but such is tinkering on old machines. I've got them all figured out...I think I'll write up some posts about them here soon.
