Old 12-03-2010, 05:22 PM
cmatthew's Avatar
cmatthew cmatthew is offline
Default hydro fluid
what type of hydro fluid does the cc123 call for?
Old 12-03-2010, 05:26 PM
ajgross ajgross is offline
Inactive Member
either "Hy-Tran" which is available at a Case IH Dealer or "Hydraulic Transmission Fluid" which is available at your cub dealer.
AJ
Old 12-06-2010, 11:48 AM
cmatthew's Avatar
10 degrees here in the north woods. should I run the hydro for a while before changing hydro fluid or just drain it regardless of the temp
Old 12-06-2010, 12:29 PM
It's always best to drain warm fluid, if it is possible.
I like to give it as long to drain as I possibly can, overnight being ideal.
Old 12-06-2010, 01:43 PM
cubs-n-bxrs's Avatar
I also like to jack up the front of the tractor and get as much as possible out of the pump.
Old 12-06-2010, 02:17 PM
cmatthew's Avatar
Default thx
thanx for the input guys. :biggrin2.gif:
Old 12-06-2010, 04:15 PM
cmatthew's Avatar
Default fluid type
I was checking round town and found some fluid from NAPA #1410 hydro fluid. I also found #303 hydro fluid from O'Reilly. I just wondering whats been heard of these two and which would be the better of the two. thanx
Old 12-06-2010, 06:49 PM
I see you're in WI...I bet you have a CaseIH or Case dealer nearby from which to procure the real thing. We just discussed this at length in another thread.
http://www.onlycubcadets.net/forum/s...ead.php?t=7561
Old 12-06-2010, 07:20 PM
JayBrd's Avatar
JayBrd JayBrd is offline
Originally Posted by cmatthew View Post
was checkin round town and found some fluid from napa #1410 hydro fluid. and also found #303 hydro fluid from o'reilly. just wonderin whats been heard of these two and which would be the better of the two. thanx
Personally, use the Hy-Trans... Where in WI are you located?
Jay N.
Eau Claire, WI
RED 82 Series...
Old 12-06-2010, 07:25 PM
lwrehm lwrehm is offline
If you are in the Sheboygan County area, there is an impliment dealer in Waldo that carries Hy-Tran, also Madsons in St Nazianz has it in gallons and I believe in bulk.
