Old 05-18-2017, 10:55 PM
Garyoh5a Garyoh5a is offline
Yep...I'm always behind, but maybe this will help somebody in future
Thanks
Old 05-23-2017, 10:07 PM
TOPDOWNRESTO TOPDOWNRESTO is offline
would like to have Jeff make one of the inner rods, already talked to him, would you be so kind and post the measurements for us.
Thanks
Carroll
Old 05-23-2017, 10:28 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Thanks
Carroll
I don't mind at all. Do you mean the threaded-on-both-ends rod covered by the chrome tube for the outer control handle?
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 05-24-2017, 08:47 AM
Yes, inner threaded tube measurements and while your there the I.D.and O.D. and length of the outer sleeve tube that goes over it. Since these are NLA thought it might be worth it for Jeff to have the measurements for those like me doing a conversion or for those that need a replacement. Some pictures may help too.
Much appreciated
Carroll
Old 05-24-2017, 06:13 PM
gsomersjr's Avatar
The outer sleeve measures 5 13/16 long, .43 ID, .56 OD
Old 05-24-2017, 06:24 PM
gsomersjr's Avatar
The handle I have is broken so I'm adding both pieces to get the total measurement. I've attached a pic of an unbroken handle also.
The center smooth section is 4 11/16 long, .40 OD
The good end has 1" of 3/8-16 threads
The broken end has (approx.) 1.75" of 3/8-16 threads
Total length is 7.5" including the machined tip that acts as a lock on the horizontal shaft.
I'm not a machinist so these measurements are just "pretty close"
Old 05-24-2017, 10:34 PM
Thanks, will keep everybody posted, Jeff does some nice work I see.
Carroll
Old 05-25-2017, 10:10 PM
Need the "nub" measurement ( lock ) on the end. 1/4" OD x 1/8" long?
Carroll
Almost there
Corrected thread size to 3/8-16 NC
Old 05-26-2017, 09:07 AM
Also and lastly for my 1650 I could use the measurements for the placement of front hydro outlet holes as I will need to do that . I have access inside or out as engine and cradle are out still.
thanks for your help
Carroll
Old 05-26-2017, 11:21 PM
gsomersjr's Avatar
Almost there
The nub is still inside the rod end for now. I haven't had time to try to get it out yet. I'm going away until next week but I'll work on it when I get back.
