Old 05-17-2017, 05:36 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Default 1450 Lift Valve Handle Removal- Suggestions??
I'm removing a dual stick from a 1450 and so far it's been pretty straight forward, even if the tractor has to be practically completely disassembled. I'm down to the last piece. I'm not sure how to get the valve handle out of the dash tower. I've got the longer thinner handle removed but the second handle has me baffled. I've attached pics. If anyone knows the secret I'd love to know.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 05-17-2017, 05:37 PM
gsomersjr's Avatar
Is it possible that the handle unscrews allowing it to be released from the shaft?
Old 05-17-2017, 05:40 PM
On the one I had the handle unscrewed and then the base slid off, the handle acts as a set screw.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-17-2017, 05:41 PM
gsomersjr's Avatar
Thank you so much! I was afraid to try that without a second opinion. I didn't want to snap it off. That's for sure.
Old 05-17-2017, 06:54 PM
I might also add that the handle rod is a sleeve with a threaded rod inside of it. You may have to take the handle off (it's screwed/threaded on also), pull the sleeve then unscrew the rod.
Old 05-17-2017, 07:25 PM
gsomersjr's Avatar
You are exactly right. I removed the handle, the lock nut, and the tube. Then I was able to put a pair of vise grips on the the threaded rod to remove it. I used penetrating oil but should have waited and let it soak overnight. It snapped. Now I have to drill it out and repair the handle since it's made of unobtainium. I should have known better.
Old 05-17-2017, 07:40 PM
Ooooh. That sucks.
If you can't get it off, JeffinPa can make you a new one. I'll look around, I'm not so sure you can't buy that piece from somewhere else. It may not be chrome, but I thought I've seen them before....
Old 05-17-2017, 07:58 PM
gsomersjr's Avatar
Ooooh. That sucks.
My uncle has a lathe and likes to tinker so I might take it over to him. My thoughts are to remove the broken part from the banjo looking piece and also to drill and tap the handle rod. The I'll screw a stud into it....or maybe just call Jeff.
Old 05-17-2017, 08:31 PM
Did it break off flush?
Old 05-17-2017, 08:35 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Then have Tim powderchrome it!
1- 1200 in pieces
1- 1864 in pieces
