Old 04-27-2017, 01:27 AM
The 782 is looking sharp!
Old 04-28-2017, 09:11 AM
SGragg SGragg is offline
Inactive Member
Progress pic. Top engine tin on temporarily; need to pull PTO and replace oil seal. But it's getting there.
My TSC has started carrying a polyurethane fuel line. I've bought similar at O'Reilly's before (by the foot) and it was kind of pricey. But this stuff was just over $6 for 5'-0", which wasn't too bad. They also sell the thicker, rubber fuel line in packaged 2'-0" lengths. A 5'-0" length would do (2) tractors, so I'll have some to spare.
Link to fuel line herer: https://www.tractorsupply.com/tsc/pr...e?cm_vc=-10005
Will continue wiring up the front and rear lights over the weekend. It's supposed to rain cats and dogs.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 05-01-2017, 09:04 AM
Inactive Member
Replaced the PTO-side engine seal and got the PTO clutch on properly (thanks ol'George and others).
Got the final wiring done for the front and rear lights. I never was a fan of the color coded plastic ends of electrical connectors. Ended up pulling them off and using shrink tubing for all the connections. Turned out nice.
Had to make a couple gaskets for the rear taillights. Turned the key and got lights! Can even hear the service minder running. Thanks Roland for the wiring diagram for the M18 into a 782; seems to be working great.
Went ahead and put on the hood and side panels. It's starting to look more like a 782 every day.
Stanton
Old 05-02-2017, 12:27 AM
Good work.
Old 05-02-2017, 06:00 PM
jcsmith jcsmith is offline
Very nice job. I especially like the dash repair and the hubcaps. Now , go get some dirt on it. Speaking of which, where are the hubcaps?
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 05-02-2017, 09:37 PM
Awesome job! Thanks for the update.
Old 05-06-2017, 03:03 PM
PACubCadet's Avatar
PACubCadet PACubCadet is offline
Looks like things are coming along. Been following this refurb for awhile. Hope to see more updates soon!
Cub Cadet 104, 107
Old 05-15-2017, 10:25 AM
Inactive Member
Actually got to ride on this 782 yesterday. First time it's moved on it's own power since I bought it last summer.
Tranny was smooth. Engaged PTO and killed engine, so have a wiring problem. Also, the hydraulic lever engaged the cylinder, but wouldn't let it go back the other way. Not sure what's going on there.
Need to get these things resolved, put the finishing touches on this and set it aside (other projects).
Stanton
Old 05-16-2017, 12:26 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Congrats on the first ride!! The first cranks and the first rides are always the best!!
Jay
Proud owner of the following:
Old 05-16-2017, 12:35 AM
Check the seat safety button.
