Old 01-28-2017, 09:38 PM
HydroCub149's Avatar
HydroCub149 HydroCub149 is offline
Default Winch on a wide-frame???
I was thinking of mounting a winch on my 149 and was wondering if there were any treads on this or anyone out there who has done this.
Cub Cadet 149 w/ sleeve hitch, rototiller, snowblade and deck, Cub Cadet 124 w/ sleeve hitch and deck Cub Cadet 1811 w/ deck and 18 big internationals 🇺🇸 🔧🐂
Brinley PP-100 plow
Cyclone Rake
Old 01-28-2017, 10:05 PM
Shotgun Clay Shotgun Clay is offline
Go look under homemade section page 3.
Scroll to about half wayish and look at ~removeable winch
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 01-28-2017, 10:06 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Guys have done it, mostly on the back as a quick and dirty lift solution.
If you were to do it, dont just bolt it to the front web because a heavy pull will distort your frame. Instead, make bracket that nearly or fully encapsulates the shoulder bolts for the quick tach. Then just use the quick tach catch for keeping the winch and everything in place.
This puts mose of the stress on bigger bolts, not to mention there is more frame structure because of the front axle bracket. Do not rely on that wimpy 3/8 rod and catch to hold the stress... or youll be sorry!!!
1- 1200 in pieces
1- 1864 in pieces
